Plasma & screen burn
Discussion in 'Plasma TVs Forum' started by Antani, May 16, 2004.
  1. Antani
    Antani
    Hi everybody,
    about this (longly) discussed topic, I did not found any quantitative suggestion on how to avoid this problem. I can only find something like "avoid static images like logos/game HUDs for a prolonged period". How would you quantify this "prolonged period"?
    Same holds true for the contrast and brightness levels, for which I found recommendations to keep them low, but for those it is much more a matter of being satisfied with the image... it is pointless to keep brightness and contrast too low in order to avoid screen brun, thus having a bad quality image.
    I am quite concerned because I want to connect PS2 and Xbox to my brand new 42" plasma screen.
    Thanks for any feedback
