Plasma recommendations...
S
Steve D Green
we've just returned a plasma (Philips 42PF9945) which claimed it was progressive on the website, but wasn't (plus the scaling was pretty terrible, and there was really bad purple noise on bright white areas on the PS2), and I'm looking for recommendations.
It needs to accomodate the following...
PC connection (hopefully one that can accept 852x480 or whatever the native plasma's size is)
Progressive component for an Xbox
PS2 through the RGB scart and look OK
It's mainly going to be used to demo games rather than HC use, but our budget is around £2500, so Pioneers and Panasonics are probably out of the question.
Any suggestions are welcome.
Thanks,
Steve
You should be able to get a panny pw6 for that money, there are others but you need to go and demo before you decide.
Thanks,
I like the idea of the add-in boards to customise the video inputs, £125 for a scart is a bit steep(!) but I think we'll probably be going for one of these.
Cheers,
Steve
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
