Plasma + PS2
Discussion in 'Plasma TVs Forum' started by dpsoden, May 3, 2005.
  1. dpsoden
    dpsoden
    May 3, 2005
    I have A Panasonic PW37 and just bought a new PS2. Is there any reason why the PS2 plays black and white on the plasma and colour on my CRT?
    Set up is PS2 to scart. Tried changing cables etc but can't think of anything else to do. Anyone else experienced this?
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Right , it could be a number of things.
    Make sure that the PS2 is set up to output RGB. Make sure the lead is RGB capable.
    I am not familuar with the pw range myself but does the scart take multiple input types? IE svideo/composite/rgb? if it does you may have to select which type of input to display in the user settings of the panal ,or you have to press the av select input button a couple of times like you do on the Viera plasma to get the right input.
    Horny dragon/ gordon/ or piers on these forums may be able to give you some better advice :thumbsup:
  3. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    are u using the media box to connect your PS2 to your PW??
    Dal
  4. BigGanja
    BigGanja
    Oct 5, 2004
    335
    Surrey
    +15
    when a videogame console outputs a B/W signal, 99 out of 100 It's a modified PAL console
    but I might be wrong in this particular case
    since you're saying on your CRT image is in colors I believe you're using the right cable, so make sure to check if the scart input of your PW7 is RGB compatible
  5. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
  6. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
