Plasma PS question
Discussion in 'Projectors, Screens & Video Processors' started by sharkbait, May 9, 2003.
  1. sharkbait
    sharkbait
    This might be a REALLY dumb question ... :rolleyes: ... but I cannot figure the answer out myself. And I'm curious ...
    How much improvement would you expect to see in PQ on a plasma by switching to PS?
    The reason I was wondering is that the plasma is a progressive device anyway and will affectively attempt to de-interlace the picture.
    Would you expect a big improvement in PQ between ... say ... the display from a PS component out DVD signal and an interlaced component out DVD signal?
    I have tried to experiment with this on my Panny plasma with a Limit 9900 DVD player. There does not seem to be a huge difference and I am wondering whether:
    i) there isn't any difference really and any improvement is psychological cos I want it to be better, or
    ii) the Limit is not a good enough quality DVD player to produce a signal with a noticable difference.
    This is not a life or death question ... was just interested in understanding this better.
  2. They
    They
    Sep 10, 2002
    171
    16
    Bristol
    It will depend upon the quality of the de-interlacing in the display and that of the source.
    If the Plasma has state of the art processing then there shouldn't be much to be gained by using a progressive DVD player.
    Of course if the Plasma video processing is only average then a DVD player with top quality de-interlacing should show an improvement, particularly with film source DVDs.
    Sounds like your experiment proves both items have similar quality processing but to what level I can't quantify. You may want to try a better DVD player with your plasma to assess the possibilities (perhaps one with a Faroudja or Sil504 processor).
