Plasma Power cable
Discussion in 'Plasma TVs Forum' started by noop, Sep 17, 2003.
  1. noop
    noop
    Hello all
    Ive recently relocated my panny 37" plasma from a stand onto a bracket on the wall.
    The original power cable supplied by panny is now too short for my requirements. This sounds a silly question but can I just get a longer lead with the same connector on it . I notice that the original has a ferrite (spelling) core on it.
    Is this recommeded to keep it on there or can I get some alternative ....?
  2. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    Yes you can, I used my the one from my sub, but I would also buy a ferrite core too, you can get them that clip on.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You can buy high quality mains leads too, if you believe it makes a difference. Or just make up your own with connectors from any good electrical shop, do the screws up nice and tight,,even put some solder in there, and as miniman says, stick on some ferrites. You might have got some spares with the screen, Panasonic put a few in the box.
  4. /\/\j17
    /\/\j17
    Jun 28, 2003
    56
    London
  5. consciouspnm
    consciouspnm
    Jul 24, 2003
    Huddersfield
    Which end should the ferrites go? The manual says at the plug end i.e away from the Plasma. I'd have thought it should have been the other end.
  6. esta56
    esta56
    Jun 18, 2003
    195
    Grays, Essex
    +8
    Could someone help me here. What on the earth are these ferrites? What do they do? When my Plasma turned up there were three (one large and two small) included and the manual shows how to fit them but gives no explanation as to what, why, when. I haven't fitted them as I assume they are to fix a particular problem. I run my DVD component through my amp and (as of last night) run Cable through a JS Technology SCART>RGB also through my amp and then take a single Component feed to the Plasma - everything seems fine.
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    They're meant to cut down mains interference on your other cables. You stick em on the mains lead. Like you, I've never seen a difference, but hey, why worry. You can clip em on later if you've got a problem, or just stick em on anyway.
  8. esta56
    esta56
    Jun 18, 2003
    195
    Grays, Essex
    +8
    Thanks MAW.
    I have got a mass of cables hidden behind my screen and amp etc. so maybe it would be a good idea to fit them as I have mains leads mixed in with speaker cables and interconnects and Component leads etc. etc. I'll see if I can see a difference.
    Richard
  9. wvoss
    wvoss
    I still have some sort of problem from interferance. DVD/PS2 are fine but sky in to JS then component in to 3802 causes me a problem. Component goes from the 3802 to a Tosh MT5 DLP PJ and when watching football the picture is randomly going darker/lighter.
    I have been advised to install ferrite clamps but not got round to it yet. I do have a mass of cables bundled together which I can't really get away from.
    Can anyone add to this before I do it:confused:
    I'll post a reply if there's any interest??
  10. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    I know PW6 has a screensaver feature which limits average brightness of the screen so that it keeps going darker/brighter depending on dynamic range of the picture. may be yours has that as well. switch it off.
  11. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Anyone know a source of ferrite clamps? I tried Maplins and Tandy/RadioShack but no joy.
  12. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    HiFiCollective. Used 'em for the first time this week. Next day delivery, and helpful aftersales.
    Cheers, Carl.
  13. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Thanks Carl.
