Plasma Pioneer 434HDE
Discussion in 'Plasma TVs' started by JTR, Dec 30, 2004.
  1. JTR
    JTR
    Hello,
    I have a Pioneer PDP 434HDE Plasma...recently the media box was away for a service and has returned with a slight fault. Perhaps someone can advise as if this is normal.
    Having problems switching on the satellite receiver....
    Switch Sky on, switch TV on & the screen goes to standby? The screen does not like the TV being switched on before the Sky receiver?
    This may not seem like a huge problem but it’s getting more difficult to turn on Sky as the TV just seems to go to standby all the time?
    This is my first time on the forum, any advice out there?
  2. reckless
    reckless
    Dec 21, 2003
    983
    28
    +30
    Sounds faulty to me. I'd call them back out if it's just been away for repair. It shouldn't make any difference which you switch on first, the sky or the tv: if you hit the power button the tv should stay on until you switch it off.
