Plasma picture quality: 42" v. 50"?
Discussion in 'Plasma TVs Forum' started by [email protected], Jun 6, 2002.
  1. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Hampton, Southwest London
    Currently considering plasma options, and I was just wondering what the difference is (picture quality, not price!) between a 42 inch and a 50 inch screen. On the strength of reviews the Panasonic plasmas seem to be the ones to look at: does anyone have any experience of the 42 inch v. the 50 inch?
    Regards
    Rob
  2. carsten_f
    carsten_f
    Apparently all current 50" sets are 3rd generation whereas the current 42" sets are 4th generation. I read somewhere that the 4th generation 50" sets should be available in autumn, so it may be better to wait a few months if you are thinking of buying a 50" set.
    Regards
    Carsten.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Rob
    As you may be aware Panasonic run two plasma lines in the UK - the Silver bezelled Consumer displays and the Charcoal bezelled Commercial displays; we tend to sell more of the Charcoal displays as they have a couple of connectivity advantages over the Silver displays.
    The current Charcoal TH-50PHD30BX 50" display is a generation on from the current TH-50PHW3B Consumer display and also offers an upgrade path to DVI connectivity that is not available on the Consumer model.
    I don't expect to see too much of a change if we do get a new model later this year - the TH-50PHD30BX model is only two months old. Probably the biggest change will be with the Silver Consumer model - though again don't expect any huge step forward.
    As for 42" vs. 50" - I've yet to have anyone swap a 50" out for a 42" display :D
    If you have the budget and the wall space I would go for the 50" display - it can be a bit more demanding of your source kit but get it set up properly and it is pretty amazing.
    Best regards
    Joe
  4. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Thanks Joe, this is helpful.
    BTW Joe, if you have sent an email to me (Robert Rees) at my work address regarding my inquiry a couple of weeks ago I have been having some difficulty accessing that email server remotely so have not collected my email for a little while.
    Regards
    Rob
