Plasma picture not clear
Discussion in 'Plasma TVs Forum' started by Raz, Mar 17, 2005.
  1. Raz
    Raz
    Hi guys,
    I've connected my Sky+ box to a new Sony 42" plasma and I'm disappointed at the picture. I'm connecting using scart-to-composite BNC and I've also tried s-video but there was no real improvement (only have these two inputs).
    Any advice on what can be done to improve the pic. In some cases it looks fine but when viewing football there is visible pixallation which is quite tiring on the eyes. Is there anything I can do to improve the signal or picture?
    Cheers.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You need to use a better signal, what model of Sony is it? Does it have YUV or RGBHV bnc connectors?
  3. Raz
    Raz
    Unfortunately not, it's Sony PFM42V1N it's actually a monitor but can't complain as it was a freebie from a client. I had to buy an expansion board to allow video inputs and the board has S-video and composite inputs. There was another more expensive board available which had the 5 bnc connectors maybe I should exchange for that but will it make a lot of difference?
  4. DaveCheltenham
    DaveCheltenham
    Oct 16, 2002
    396
    Cheltenham
    +49
    Raz - Sky+ has a very good S-Video out which although may not be the ultimate, can be almost as good as RGB.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You've got a VGA port though? Check the manual, if you have one. You want to look at the horizontal sync frequency. If it can take 15.625Khz, you can use a 'sync separator' like the JS RGB to VGA, or keene synchblaster. That will give you a picture to be proud of. Alternatively look in the screen setup menu while on the VGA input, and see if you can switch it to accept component or YUV or Y Pb Pr signals. That would be useful too.
