Plasma picture delay with XBOX ??
Discussion in 'Plasma TVs' started by Darbyweb, Jul 5, 2004.
  1. Darbyweb
    Darbyweb
    Mar 18, 2003
    57
    Bedfordshire
    I dont know if its my setup up, but i'm sure there are problems with timing/plasma processing signal. Im using a Pioneer 434... - the one without the tuner.
    If i play on a Portable my usual standard of crap provails. But if i use Plasma i move up into the ultra crap league :(
    Initially i thought it was the RF controllers, then because i was too close, but now think its something else.
    I'm cascading the Xbox through, DVD, Sky+, Netgem then into a JS RGB to Plasma convertor. - Would this cause delays ??
    Theres a whole range of inputs in the Plasma, VGA, DVI, and the one with lots of BNC's ? - the VGA does Sky etc. DVI does PC, so can i use the multi thing for the XBox ?
    Any suggestions appreciated as i'm doing v v poorly on XBox Live.
    Dean.
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    It's a known issue, the dead zone, where it seems to take too long to respond to controls. I know of no cure, Pioneer are the worst culprits in my experience, for this and audio sync problems.
  3. Darbyweb
    Darbyweb
    Mar 18, 2003
    57
    Bedfordshire
    I was worried that would be the answer.
    So i now have a state of the art living room, and cant play my XBox :(
    Suppose its probably ok for everthing except racing (my favourite genre)..
    I'm certainly not about to swap the Plasma..
    I had noted the audio delay, but seem to have cured this more by luck, and play the DVD-R's audio while watching the Sky+ output, this seems to inject just the right amount of delay.
    Off now to play my Xbox on the 14" portable in the Bedroom - how humiliating.
    Dean.
