Plasma over a fire = Damage ?
Discussion in 'Plasma TVs Forum' started by simmo, Mar 15, 2006.
  1. simmo
    simmo
    Feb 8, 2004
    342
    Lincs
    +9
    Thinking about buying a plasma and fitting it to chimney breast over fireplace.Little concerned about the heat coming from fire damaging plasma.Have seen pics of other people who have installed their plasma's over fires but just wondering if this will cause damage over time ?
  2. rudy
    rudy
    Jan 2, 2005
    499
    Depends on how hot the fire is:D
    Post a picture
  3. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    Simmo
    Have a look at the thread entitled "Get your your plasmas out for the lads"
    http://www.avforums.com/forums/showthread.php?t=78824
    You will see numerous over the fire plasmas - just make sure you take precautions ie mantle find out how hot it gets directly above the fire etc
    You might find the warranty will be null and void if it gets fried
    Regards
  4. koti
    koti
    Feb 11, 2006
    101
    Warsaw
    +6
    What I would do is leave a thermometer for lets say 24 hours in the place where you want to mount your plasma. Make a big fire in the fire place, wait a few hours untill everything gets realy hot and compare what You see on the thermometer with operating temperatures in the Panasonic pdf. Plus its always good to use your common sense You know? :p
