Plasma or SVideo Lead?
Discussion in 'Cables & Switches' started by Skids, Mar 18, 2005.
  1. Skids
    Skids
    Mar 18, 2005
    7
    Hi.
    I have just bought a Techwood Plasma and I am fairly happy with it. (I know some people will tell me I shouldn't have bought it but it was all I had the budget for)
    I also have a Pioneer DCS 303 DVD player which only has SVideo out and I have noticed that red is sometimes slightly shifted to the right (I noticed this in The Incredibles which has a lot of red in it!) although it isn't really colour bleed.
    I bought Digital Video Essentials and have it set up to the best I can.
    Anyway my question is, would buying a better svideo lead help this or is it because it is a cheap plasma or could I actually have a problem with the plasma that I should get sorted under warranty?
    Also woul this help with the solarisation that appears although that is not that bad.
    I have a £20 pound interconnect Svideo lead but I have got my eye on a £35 Ixos svideo lead (Is this a good choice?) but I don't want to fork out that sort of money if it isn't going to make any difference.
    Many Thanks in advance.
    Skids
  2. Skids
    Skids
    Mar 18, 2005
    7
    Does anybody have any advice please.
    I am thinking it is the cable because the colour from Sky (Via RGB Scart) is fine.
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i reckon you will get more advice in the plasma forum mate
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,570
    The Borders
    +3,029
    Skids
    A better engineered cable may make a difference - though ensure you get a cable on Sale or Return so you can try it in your system without committing to a purchase.
    I'd recommend one of these (http://www.bettercables.com/svideosvhs.html) - a bit more than the Ixos you indicate but do make a difference over any other S-Video cable we've tried.
    Best regards
    Joe
