Plasma or LCD If Plasma Which one?
Discussion in 'Plasma TVs Forum' started by Shakti, Mar 16, 2006.
  1. Shakti
    Shakti
    Mar 16, 2006
    24
    I am in the market to buy Plasma HDTV. Can anybody guide me which one to go for? And where can I get the best value for my money?
    I don't know much about LCD but with my limited search, I have formed the opinion that LCD is not in par with plasma as yet!!
  2. oxy
    oxy
    Dec 11, 2005
    188
    16
    Oxford
    You really need to expand on this , ie what size do you want,
    what are you going to use it for apart from hd that is ,
    do you need a stand ,
    internal tuners/freeview etc
  3. Shakti
    Shakti
    Mar 16, 2006
    24
    I am thinking about 42" to 43" which has connectibility of cable box, dvd & home cinema system. I don't need stand as long as it has attached table top stand. I need tuner and integrated speakers so it could work as stand alone TV. The picture quality and the reliability is very important to me.
  4. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    And Your Budget Is... ??
  5. Shakti
    Shakti
    Mar 16, 2006
    24
    Say I can strech to £2500.00
  6. johndon
    johndon
    Feb 3, 2002
    1,989
    63
    +122
    LCD v Plasma is VERY much a personal opinion and you will, of course, get very different answers if you post in the LCD forum.
    Do a forum search for 'LCD v Plasma' and you'll find this has been discussed dozens of times.
    John
  7. drguptagaurav
    drguptagaurav
    Jan 8, 2006
    256
    +3
    I have recently bought a 436xde ( £ 2200 )and love it . :D . In my opinion LCD are not that great for big screens esp viewing angle which by the way is almost 180 deg for 436xde !!!!!
    There are 2 options if u wanna buy the big daddy and put it on wall go for pio 436xde . If u wanna put it on a stand and spend sensibly hitachi pd 7200 or 7500 ( £ 1411 on Dixons )
    :smashin:
    gaurav
  8. gsagos
    gsagos
    What about buing PDP-506XDE and putting it on an ATACAMA Equinox AV stand?
