Plasma or DLP, Which is best for HD?
Discussion in 'Televisions' started by YorkieAnd, Jun 8, 2005.
  1. YorkieAnd
    YorkieAnd
    May 19, 2005
    22
    After weeks of deliberating I can't make my mind up between the new 42" Panasonic 500 plasma, and the Sagem Axium 45DLP. Pricewise there's not really that much between the two. Anyone have strong opinions either way on which is the best for future HD broadcasts? Also which is the better option for the current SD broadcasts? Thanks for any help.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Both technologies have their pro's and con's. You need to make a list of them, and then decide which are more important to you. I won't waste my time and yours listing them now, because I'm sure you will find all you need in the relevant forums.
  3. tim k
    tim k
    as far as SD goes i think the pv500 has been found to do the best job, the sagems are strong on the hd front, but for the money (well less) you could have the samsung sp50, this has had a few hd issues, but with the right tweeks is as good as the sagem and you get more screen and i think better looks. but if it was me id go for the pv500 with cabinet (can be found for £2200) over the sagem.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    OK, I've got a bit more time now, so here goes.....
    Plasma "Pro's":
    Plasmas use similar phosphors to CRT, so colour rendition is excellent.
    Plasmas have a very wide viewing angle.
    Plasma screens do not flicker.
    Plasma screens are very bright.
    Plasmas have a good lifetime expectancy (30,000 to 60,000 hours)
    Plasma screens are very thin panels.
    Plasma "Con's":
    Plasmas are quite expensive.
    Plasmas can suffer from "screen burn"
    Plasmas are very heavy.
    Plasmas use a lot of power (about 350W for a 42" screen)
    DLP "Pro's":
    DLP tv's are quite cheap
    DLP tv's don't suffer from screen burn
    DLP tv's can give very good HD performance for a cheap tv.
    DLP "Con's":
    DLP TV's can be noisy (motor & fan inside)
    DLP TV's have a lamp that can be expensive to replace
    DLP TV's have a larger footprint than plasma
    DLP tv's have a narrower viewing angle
    DLP tv's suffer from the "rainbow effect"
    Can't think of any more....
  5. NicolasB
    NicolasB
    Oct 3, 2002
    5,880
    Emily's Shop
    +566
    Samsung (and some other companies) will shortly be releasing some 1920x1080 resolution DLP screens in america. I don't know if we'll see them here but, if we do, then that raises the possibility of a 1920x1080 screen, anything from 50" to 65", costing an amount of money that is comparable with what one would pay for a plasma no larger than 50" with a resolution of no more than 1366x768.
    However, there's an awful lot of speculation in that assessment. :)
  6. kourosh
    kourosh
    Feb 6, 2005
    13,838
    Portsmouth
    +907
    dont let people decide for you the best way go and demo the sets your self take films with you and make sure test every thing 1 thing i can say dlp tv are not very good with a analoug areial you do need a digital picture i have a toshiba dlp and let me tell u i also work for sony there isnt a plasma or lcd that sony makes comes near the picture quality of this set and these are only the 1st generation sets this is how the picture quality rates in these sets
    1=crt
    2=dlp
    3=lcd
    4=plasma
    but hey dont listen to me do the tests :thumbsup:
  7. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    Plus Sony have launched (or are launching) their own flavour of LCOS (SXRD LCD) reflective LCD at 1920x1080 for their Qualia 70" RPTV in the US.
    I saw one of these in the NY Sony Store in January and the picture quality blew every other RPTV I've ever seen out of the water.
    I also saw quite a lot of direct view LCDs and Plasmas, and a couple of DLPs running HD signals yesterday at a BBC R&D Open Day - and the plasmas and LCDs looked MUCH better than previous demos I've seen. I think where they fall down is coping with poorer SD signals...
  8. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Sorry, mate, I'd rather listen to you than try to read your post. 97 words without a punctuation mark or capital letter is a bit heavy going ! :)
  9. kourosh
    kourosh
    Feb 6, 2005
    13,838
    Portsmouth
    +907
    Sorry,did'nt know we had a teacher in here!! im sure if it was an english forum you would be top of the class ;) there you go sir mark this post :lesson:
  10. kourosh
    kourosh
    Feb 6, 2005
    13,838
    Portsmouth
    +907
    The sxrd qualia is coming out in december time,for the uk they are planning a 55" version this tv will set the standards :eek: :clap:
  11. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,011
    2
    4
    137
    Garstang, Lancs
    +1,575
    Sorry, I didn't know we had a teacher in here!! I'm sure if it was an English forum, you would be top of the class.
    There you go Sir, mark this post.
    :D
  12. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    Sorry to be pedantic, but I don't think you can put two exclamation marks at the end of a sentence!
    Is there an English teacher on the forum?
    :devil:
  13. kourosh
    kourosh
    Feb 6, 2005
    13,838
    Portsmouth
    +907
    know ie now yi ie caim boottome ofe thuey clloss :rolleyes: :rotfl: :rotfl: :rotfl:
  14. Kramer
    Kramer
    OK guys, back on topic please :thumbsup:
  15. VisionOn
    VisionOn
    Jun 4, 2005
    Carrboro, North Carolina
    I've got a JVC LCoS unit and it's pretty good but I've been drooling over the Qualia 006 ever since I saw the first pictures.
    Click here for some good owner pics and review links of the 006 over at the US AVSForum.
    Given the price of it, drooling is about all I can afford. :)
  16. kourosh
    kourosh
    Feb 6, 2005
    13,838
    Portsmouth
    +907
  17. lukemh
    lukemh
    please dont forget there are 2 types of DLP single and three chip if you can afford the 3 chip it will blow you away
  18. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    I second the posts about the Qualia 006. Saw one in NY and it blew me away. Massively better quality than single chip DLPs or 3 panel transmissive LCDs.
    It uses 3 1920x1080 reflective LCD panels (not transmissive) - like LCoS. I guess 3 chip DLPs will offer similar quality...
  19. electrosim2001
    electrosim2001
    Nov 22, 2004
    101
    To be strictly accurate....... I'm sure that if it were an English ..... ( etc. )
  20. darrens
    darrens
    Nov 2, 2003
    97
    Just to say thanks to Nick_UK for summarising the plasma/dlp pros and cons. I'm about to buy a new 50" TV and was a bit confused as to whether to get plasma or DLP. My criteria or more about picture quality than practicalities/aesthetics and I was beginning to get the impression that DLP was actually a better PQ.
    But given most of what I watch is Sky (rather than DVD) it sounds like plasma is my best option ... since they don't make a 50" CRT or LCD.
  21. kourosh
    kourosh
    Feb 6, 2005
    13,838
    Portsmouth
    +907
    i dont know if you can wait a few more months? but wait for the new sony :rolleyes:
  22. mike7
    mike7
    Jan 3, 2005
    4,577
    Norwich
    +492
    I saw a HDTV demonstration yesterday in my local Currys (would you believe!) It was on a Sagem DLP and the video came,via DVI, from a computer. The picture was probably 1080i. The source material was mainly American and the overall effect was very impressive, but stuttery. This may be a 50/60Hz conflict. No opportunity to hear any sound though. This was in Norwich. Might be a promotion that Sagam are doing elsewhere.
  23. sprattgraham
    sprattgraham
    Dec 10, 2004
    928
    28
    Hertfordshire UK
    +28
    The Stuttering you sore was probably the PC working flat out trying to play the HD
    When I watch HD from Euro1080 my processor is running at 80%. Even if the Video was 1080i in currys your not seeing 1080 lines only 720.
    I’ve watched US DVD’s and the Sagem works fine.
  24. YorkieAnd
    YorkieAnd
    May 19, 2005
    22
    lukemh said
    Luke (or anyone else) can you give some examples of three chip DLP's please. Many Thanks.
  25. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    There aren't any in the UK as yet and if and when we do get them they will be be very expensive, at least initially, compared to the single chip DLP TVs.
  26. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
  27. ash
    ash
    Jun 9, 2005
    11,044
    +383
    How mucvh does that cost? Any reasonable priced ones/
  28. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Around the 4k mark :D
