P
Paulo88
Hi all,
I've just opened my FREE wall mounting kit that came with the Panasonic TH37PW7 Plasma TV. The bracket is about 2" tall and about 28" wide. Something like this...
I O o O o O o O o O o O o O o O I
The plasma then hangs via a bracket from this. As you can image this doesn't give it much service area to spread the weight across just plasterboard. (No there is no wooden beams behind the plasterboard !! Its just dot and dab plaster. )
So my idea is to bolt a piece of wood to the breeze block behind the plasterboard making sure that this has a good fix, then bolt the above mount to the wood.
Your thoughts as ever are much appreciated.
Is this sure to send my plasma to the great plasma heaven in the sky ?
Or
Do you think as long as the wood is secured well enought to the wall the plasma should hold ?
