Plasma mount help needed
Discussion in 'Home Cinema Building DIY' started by neilk75, May 1, 2005.
  1. neilk75
    Hi everyone, im planning to remove all the plaster from my solid wall downstairs living room to fit HC system. I need to do two things
    1 remove a layer of bricks enough to fit a 42" plasma screen and approx 5cm all round for ventilation, does anyone know building regs/good method.
    2 I will be putting the av gear in the cavity where the fire place was and burying all the cables before replaster. It seems the best way to run the cables is to come from inside the chimney from behind the plasma, does anyone know a good futreproof way, ie addition of extra HDMI or scart.
    Any help would be much appreciated
