Plasma-LCD and viewing distance
Discussion in 'LCD & LED LCD TVs' started by Dreamboy, Jul 1, 2004.
  1. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    I'm considering a new parameter when buying my new TV. The distance I have from my seat to the wall is not very far (3 mts./9 feet).
    I don't know if this is too close for a 42" plasma or maybe a 30" LCD will be better. I personally think that plasmas looks better at short distance that LCD's. Images seems more "soft".
    What do you think about this?
  2. reckless
    reckless
    Dec 21, 2003
    983
    28
    +30
    I was a little concerned when I bought mine as I thought it would show up imperfections at that range. However, I was delighted and felt that it was fine.
  3. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    That's my worryes. I don't know if I will see some imperfections. I know this displays look great at a few meters. But at 3 or less maybe they're too big.
    Thanks for your comments.
  4. osmyth
    osmyth
    Nov 10, 2002
    278
    16
    York
    I have a 37" pe30 plasma on a stand. I had it in an alcove at 8ft viewing distance and think that it's very slightly too close (smoothness wise). I have moved it to another part of the room with 11ft viewing distance and this is ideal (smoothness wise), although probably a 42" would be the best of both worlds at this distance.
    Owen.
  5. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Mmmm... The problem is that my livingroom has a rectangular shape. It's 8 meters long but only 3 meters wide. And I have to put the TV on the side wall. The problem is that until I don't see the TV installed I'm not sure if it will be too big.
    Anyway 3 meters is the shortest viewing angle. Looking at the TV from a side distance is bigger. I hope to make the right decision.
  6. betamac
    betamac
    I have mine on a wall and sit about 3 metres away and its perfect,
  7. Dreamboy
    Dreamboy
    Jun 15, 2004
    109
    16
    Cool!!! Then I hope it will be perfect for me too. I always try to look at the screens at the same distance when looking at them at the shop. But it's dificult so have same distance reference and watching position.
  8. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Mine is about 3.5m away and its perfect.
  9. Geomath
    Geomath
    Jul 22, 2004
    55
    Sunny East Hertfordshire
    Words are fine for TV but what about reading web pages and PC work?
    I've in the 3-4m view range and have bought a multimedia PC sans screen. My gut feel is minimum 30" but anyone have experience of operating a PC at a distance?
