plasma interference
Discussion in 'Plasma TVs' started by steevs, Apr 14, 2003.
  1. steevs
    steevs
    Jan 3, 2003
    2,874
    68
    wxm
    +71
    Hi guys,
    Just wondering if anyone is having problems with interference on their panel, mine is especially noticable when outputting NTSC, I have contacted the manufacturer and was told it is caused by other electrical equipment in my home.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,013
    +2,809
    What interference? What plasma? What sources? What DVD's? How is the source wired to Plasma?
    Gordon
  3. steevs
    steevs
    Jan 3, 2003
    2,874
    68
    wxm
    +71
    Interference is diagonal lines accross the screen, I have it connected via component, interference isnt there on the other inputs. It is a Relisys plasma screen.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,013
    +2,809
    If you see diagonal lines moving across screen only with NTSC material from DVD then it's likely an earthing problem in your system. It might even be an issue with earthing at consumer units in house rather than with the equipment in the actual system. These things are notoriously hard to track down. Good luck!
    Gordon
  5. steevs
    steevs
    Jan 3, 2003
    2,874
    68
    wxm
    +71
    Thanks gordon for your help, I'll just have to connect it up via the vga with a syncblaster I guess, no interference on that which seems strange to me.
    anyways thanks for the help.
    Steve
