Hi there,
I've been dropping in on these forums for a while now and have finally got to the point where I need some specific advice!
We have just bought a new house and the first plan when we move in is to redecorate the front room and I've convinced the other half to let me build a fake chimney breast to mount our new tv in!
Having checked out many of the posts in the "Which LCD TV should I buy?" forum I thought I had narrowed it down to the Panasonic TXP37X10 plasma based on the several recommendations it has been given to other people in a similar situation to me (it will predominantly be dvd and standard Sky viewing).
However, I downloaded the manual from Panasonic's site and it states that it should be given a clearance of 10cm on all sides and to me that sounds like it will look a bit rubbish if mounted in the wall with a 10cm gap. Can any of you who have mounted tv's in the wall advise what gap you've left and if any of you have mounted a plasma, did you leave this kind of gap and if so, has it caused any issues?
Cheers in advance,
James
Cheers in advance,
James
