T
tonydavies
Couple of questions....have decided on purchasing one of the Panasonic 42 inch plasma's.....but need to decide which model, and which input box would be best for me.
Would probably be using a hcpc to play dvd's, vga out?.....an x box and a gamecube...uk version...may upgrade to us versions due to there progressive scan capability, and the plasma's ability to display progressive scan. Would also look to plus in a sky digital box for tv reception.....
So input devices would be:
hcpc,
xbox/gamecube,
sky digibox......
Also how do people rate the de-interlacing/scaling of the circuitry found inside the Panasonic plasma's.......
Best regards
Tony
hcpc,
xbox/gamecube,
sky digibox......
Best regards
Tony
