plasma help
rav79
Joined
May 11, 2009
Messages
43
Reaction score
Points
14
thinking of buying a tv above 46" and have a budget of £700
it must have 5 years gaurentee
do i need 1080p
i have no blueray or games console
just have virgin hd
mainly used for day to day tv and movies
is a plasma better or lcd
thinking of getting the lg 50pq3000
am i making the right choice
is screen burn an issue
or shall i get a lcd LG 47LG5000+Wall Bracket - £738
Well, 46" under £700, then you'll only get cheap sets, look in the LCD forums, sorry. :smashin:
so is the pq3000 PLASMA no good
i hope others are as helpful as you
I'd say it's well worth it, £699 at John Lewis with 5 yr warranty. SD through the
V+ box will give a very good picture. With you not using it for games, IR or screen burn will not be a problem at all. Nip in JL and give the 50" the once over, but it will still look alot better in your own home after you have connected it to your V+ box, and tweaked the settings slightly. Good luck. :smashin:
thanks klythawk a much more helpful comment then rewerb
Rav - you have an obvious choice here with your price range. I think £740 will buy you a Panasonic 50" X-10 online. The 5-year guarantee might be a problem though as youd need to buy it in person from a dealer and the price would probably go up a bit so shop around and see what deals you can get.
The X-10 is a nice set and in that price range its the only one I would even consider.
Check the X-10 thread for more advice - Im sure they can help you out and you can read about all the happy people who own one! (Ive got the G-10 but thats out of your price range)
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
