Plasma Help (First Time Buy)
Discussion in 'Plasma TVs' started by Publican, Aug 27, 2005.
  1. Publican
    Publican
    Hi Guys
    I come to you in desperation :lease:
    I have 1500 pound to spend on a plasma tv,dont need speakers nor do i need freeview,not too bothered about HD either.Please can anybody give me some reccomendations on what to buy as ive trawled the shops and the net and cant find my way out of this maze.Ideally looking for 42 inch screen with 1024 res.oh and i dont need a stand or mount either. We only wanna watch sky and play DVD's but would be nice to get the best bang per buck.
    Thankyou in advance
    Chris
    Cambridge
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Hmm, best bang for buck with sky and DVD, is this in a pub? will be a trip to Richer sounds for a £999 Panasonic PWD7. You'll also need a bracket, and a JS RGB to VGA converter. Total, maybe £1250 inc cables. There is no great advantage to high resolution, other picture qualities far outweigh resolution for percieved image quality. You may also consider ultimate robustness for screen burn to be important if this is commercial, again the Panasonic wins hands down. There, I'm risking a flaming for being so direct and also so pro Panasonic, but I speak as I find.
  3. Publican
    Publican
    Thanks for your response.We do run a pub but the plasma will be for own use upstairs! The plasmas downstairs in the bar are Philips 42 inch jobs but come with speakers and freeview and we dont need either upstairs.Was hoping to place our new plasma on a nice stand we have seen from currys in addidtion to the sony 5.1 dvd/amp we have our eyes on.
    Many thanks
    Chris
    Cambridge
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Most of the comments still hold water, you'll need a stand instead of wall mount. The Sony DVD, make sure it has RGB scart or component video, or it will look pants on a plasma.
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    MAWs right, you can't beat the panny from richersounds
  6. Publican
    Publican
    Thanks for that.
    I have just called Richer Sounds and they still have the TV's available at £999.95 BUT I need a 'Media Box' at £150 (!!) and a wall bracket or stand to put it on a cabinet at another £150 (!!). Total price of everything £1300.
    Can I get the media boxes any cheaper? Or will I be beter off buying a Plasma with everything built in?!?!?!?!
    :rolleyes: :confused: :rolleyes: :confused: :rolleyes: :confused: :rolleyes:
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,784
    Norwich
    +664
    What media box? If they are talking about the tuner that is the last thing you want, it turns an awesome screen into a crap one!
    You need a JS RGB-VGA converter to convert the RGB out from your scky to VGA that will go straight into the plasma, with a nice sharp image.
    www.av-sales.com are doing a foum offer of £1150 delivered for the screen, a wall bracket and an iput board giving you component, s-video and composite inputs to add the the standard VGA that is on the screen out of the box.
    So you would go, sky to screen using vga converter and then DVD to screen with component, this would give you the best results for least outlay.
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Or daisy chain sky and DVD. But this is unfair sales by Richers, the media box they are stuck with cos it's so crap. Let them keep it, though the original list price was £600!!
  9. Essexdad
    Essexdad
    Hello guys........hope not too off topic....just bought Samsung 42S5S, for use with Humax F2-Fox Freeview , and DVD with Component out....would I benefit from the RGB to Plasma converter you're talking about? I see they also do a RGB to Component converter as well, could this be used as well by in some way combining the leads from the Freeview and DVD outputs ?
    Thanks for listening anyway !
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    We're all used to off topic... I don't think you've got anything to gain from either of the boxes unless you have a surround sound, used all the time, with component video switching. If your picture is not right you need to make sure it's in an RGB capable scart, with a fully wired lead, and RGB is enabled at both ends, then start gently tweaking the picture settings. The VGA converter won't work on your Samsung AFAIK, the sync frequency is too low.
  11. Essexdad
    Essexdad
    Thankyou MAW,for you advice
  12. Publican
    Publican
    :rolleyes: ...I only wanna buy a plama telly.How hard ca it be :eek:
  13. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,784
    Norwich
    +664
    What dvd player an surround are you getting? we are all guessing how to hook it up, but we don't know what outputs your kit has.
  14. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    LOL it seems that way! It's not hard at all, but you have to ask yourself, how many of us could run a pub!
  15. Publican
    Publican
    This one..Panasonic SCHT880W Hi-Fi Surround Sound
  16. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    I love it when shops try to sell "extras" that you don't really need like media box, cables, stands at 2x the going rate
    mind you I had plasma feet from richersounds for my PWD6 for £50 (they soon stopped selling those)
  17. Publican
    Publican
    I was under the impression that i needed this "media box" if i was to buy this panel from Richer Sounds :confused:
    LOL What a palavor!! :eek:
    Chris
  18. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Not at all, you can get TV on a PWD7 with no boards at all, or media boxes etc. You do need either a video board or a 'sync separator' to make them work with a set top box. I assure you, Richers just have too many of these media boxes, they are horrid beyond belief, and nobody on the forum uses them, they all go by other methods once they find out. I'm sure I will have the total backing of all here in this.
  19. Publican
    Publican
    Not sure i understand all of that but i'm gonna be keeping an eye on what you guys think as were gonna take a trip to Richer Sounds armed with the advice tomorrow
    Keep the info flowing :)
    Chris
  20. Publican
    Publican
    Hi again..
    Just to get everything straight in my head....... based on the info so far:
    I am purchasing a PWD7 from Richer Sounds with stand and a RGB to Plasma VGA Converter to enable me to connect everything we need to to it?!?!?!?
    We will need to connect a SKY box, and a Sony DAVDZ500 DVD/Speaker System
    Thanks again for everyones advice so far
    Cheers Chris
  21. peterakastorm
    peterakastorm
    Make sure the Sony DVD/Reciever system has component out...!
  22. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    Assuming that you have already got two decent scart leads (one for Sky and one for the Sony) you will also need a VGA to VGA cable (for the output from the J S Technology RGB to VGA converter). Job done.
  23. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    Peter,
    The Sony doesn't have component out (according to Sony's website) and without a component board in the plasma Publican wouldn't want that anyway.
  24. Publican
    Publican
    So i'm still cool then. Shopping list then is:
    1.PWD7
    2.Stand/Feet for above
    3.J S Technology RGB to VGA converter
    4.VGA to VGA cable
    5.A large whiskey!
  25. peterakastorm
    peterakastorm
    Thats right... But then I would get a component board, and a component cabable DVD-player ;) But that's just me, hehe.
  26. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    The shopping list now looks good :thumbsup:
  27. Publican
    Publican
    Is this the vga-vga your on about?
    Standard VGA lead for RGB to Plasma VGA. £22.00
    Click to enlarge
    One of the many advantages of the RGB to Plasma VGA unit is that you can use a variety of cables. Our standard Standard Quality lead have gold plated pins with 75 ohm matched cable for video transmission. Includes thumbscrews for secure attachment.
  28. Publican
    Publican
    :confused: :eek:
  29. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    If that quote was taken off the J S Tech website (and I am guessing it was as the price is right) then yes that is the lead you need though the slightly more expensive VDC lead is better.
  30. Publican
    Publican
    Yep,gonna go for the more expensive lead..
