Plasma goes Light and Dark now and again
Discussion in 'Plasma TVs Forum' started by mstodge, Jun 18, 2004.
  1. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    i've had my pioneer pdp434hde for two weeks now and every now and again it goes light then dark, light then dark, light then dark and so on.
    Do you think this is a problem with the set or to do with some of the settings.
    It happened when i first got it, then stopped (but i have been messing around with the settings a lot) then i noticed again today.
    Apart from this i am very happy with the TV.
    Mark.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,228
    The Borders
    +2,938
    Mark
    If your sending a Progressive signal into the Display from a DVD via YUV on Input 03 and also have the PureCinema mode in the > Picture > ProAdjust menu set to Standard or Advanced the Display can get in a pickle with some material.
    Reset the PureCinema mode to Off and you should resolve the flicker.
    Best regards
    Joe
  3. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    Thanks for the reply.
    I forgot to mention that it only seems to happen when watching Sky+, dvd's are fine, also i've got the PureCinema mode off. it's difficult to diagnose cause as i said it only happens now and again.
    Mark.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,228
    The Borders
    +2,938
    Hello Mark
    First off (and assuming your using a SCART cable with your Digibox) I'd reseat your SCART cable at both ends - it could be slightly loose.
    Best regards
    Joe
  5. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    Thanks, I will try that.
  6. PC Nut
    PC Nut
    Jan 11, 2004
    648
    South West
    +64
    Make sure also that sky box and 434 are set to RGB
  7. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    Pc Nut,
    Set to RGB already, The scart lead was hanging out a little like joe said, so popped them back in and all seem well so far.
    How is the 868i, would you recommend one?
    Mark.
