Plasma Gamma setting,Whats it for?
lucas22
I currently own a panasonic 50px70 and although iam happy with the set i have noticed when gaming(xbox360 over vga)sometimes dark scenes can be prone to flickering.
My point is this,the gamma setting in the menu is currently set to s curve.
What are the gamma settings for?what do they do?and might this help with the flicker as mentioned above.
AS always many thanks in advance:)
arad85
Depends what you mean by "flickering". All gamma does is alter the mapping of input values to output drive power (see http://en.wikipedia.org/wiki/Gamma_correction). I doubt if it would help with flickering (unless you mean something different to the normal use which is a refresh rate problem like you get on monitors).
lucas22
Best way to describe it would be when a dark scene appears on screen it seems to struggle to find the correct shade,in other words it will flicker between the correct shade and a lighter shade for a few seconds before settling in.
hope that makes sense:)
Lin3ar
Here is a very good description:thumbsup:
http://www.*/news/what-is-gamma-20080511108.htm
lucas22
Thanks for that lin3ar.
Although this may not solve this particular niggle, it offered me an insight into an element of plasmas/lcds i had not thought of before for instance the fact that mine is set to s curve which they dont recommend saying that it gives the picture an unnatural feel.
Might have some experimenting to do later.
