Plasma for work - which one would you choose ?
Discussion in 'Plasma TVs Forum' started by common, Aug 13, 2003.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Any advice ? - it will be used mainly for a PC display
    MZ50PZ43 LG 50" 2YR ON-SITE WARRANTY - £4445.00
    PS50MP2 NEC 50" 2YR ON-SITE - £5125.00
    CMP5000 HITACHI 50" 1YR REPLACMENT - £4895.00
    PDS50XCA11EH FUJITSU 50" 2YR Return to base - £4875.00
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    If it's for a PC display, particularly anything that involves graphics/pictures, your key driver is square pixels.
    Look for a screen that's physical pixel resolution matches it's 16:9 aspect ratio -- at 50" you are talking 1366x768 resolution. Anything else will distort the shape of images.
    Furthermore, to get the best of the screen you need to ensure that you have a graphics card that can display this non-standard resolution and you will need to user Powerstrip to set up a custom resolution of 1366x768 (very easy to do).
    Finally, you may want to consider refresh rates -- like monitors the higher refresh rate you can get the better (less blurring on movement).
    StooMonster
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,555
    The Borders
    +3,026
    Common
    What's the application - who's looking, from where, for how long and what info are you looking to display.
    Where is the source in relation to the display and what resolution and signal type is it outputting?
    Best regards
    Joe
  4. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Joe,
    It will have 2 uses
    1. Boardroom on stand - 12 people max connected to a standard P4 PC.
    2. A repeater screen for the main training room with a projector acting as the main image - again connected to a standard PC
    Not sure on resolution - any more advice would be appreciated
    The source will be in the corner of the room, but connected via a number of available floorboxes
  5. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I use Fujitsu 5004 at home exclusively through HTPC. You can find the exact resolution settings here. This maps pixel for pixel graphics card and plasma. I use cheapish ATI Radeon 8500.
    Plasma properly detects monitor sleep modes so it goes into stand buy when PC is switched off or goes to power save.
