Plasma "feet"
Discussion in 'Plasma TVs Forum' started by swarrans, Sep 23, 2004.
  1. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I'm getting close to taking the plunge on a Panny plasma and was wondering about a stand - I helped a friend buy a 4 series Panny before and it came with 2 little plastic feet for free, that as long as the screen was protected from failing over acted as an adequate stand.
    Anyone know if they are available or come with the 6 series?
    Simon
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No they don't. The cheapest feet are from Richers, about £50
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    We have a set for demo use, and shows etc, they are not particularly beautiful, but then there's not much to them, so you don't really notice. And they are 1/3 the price of a Panasonic stand, for the hard of bank balance.
  5. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    Thanks Chaps!
    Simon
  6. novaya_zemla
    novaya_zemla
    Empire Direct have the round stand for £134
  7. jedimaster
    jedimaster
    Hi, Can you please tell me if you have a a pair of plasma feet or possibly an ex-demo/used pedestall/table stand for a Pioneer 433MXE. I just need the stand/feet for a short while until I wall mount the plasma hence dont really want to spend too much. Your help would be much appreciated
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    We bought ours from Richers!
  9. jedimaster
    jedimaster
    I have checked Richers and they do not have any and they dont know when they will be getting some in ?
    Anyone out there got some plasma feet for a Pio 433MXE ?
    Regards
  10. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    If you've just bought the screen, it comes with 2 plastic feet that it kind of clips on to, so the impatient new owner can get it fired up. They might do you for the time being. They are the grey plastic things in the accessories box.
