Plasma faq/buyers guide?
Discussion in 'Plasma TVs Forum' started by James45, Dec 18, 2002.
  1. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    okay so you lot have put this crazy idea in my head about getting a plasma next year but I know nothing (and I mean nothing) about Plasma technology, limitations, basically the kind of things you should know before you fork out thousands on a piece of electrical equipment.
    Can you suggest any good (trusted) places to start my research?
  2. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    Without wanting to state the obvious - the best place to start is right here!
    Look through past posts or do searches - you will find loads of real-life reviews, experiences, problems, fixes etc for all sorts of plasmas from real normal(?) people - sometimes a lot better than magazine reviews etc.
  3. James45
    James45
    Sep 21, 2002
    2,844
    59
    I started looking through this forum yesterday for the first time and while it's given me some help, I really wouldn't know what to search for with regards to plasmas. A lot of this stuff is quite in depth (or assumes you know something about plasmas, resolutions, scaling, prog scan, HD/LD and the like) and has been flying straight over this plasma newbie's head.
  4. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
  5. James45
    James45
    Sep 21, 2002
    2,844
    59
    thanks Codlord
    also found an FAQ on the OTHER site!!
