plasma export to spain
Discussion in 'Plasma TVs' started by julio, May 31, 2005.
  1. julio
    julio
    hi peeps is there anyone that knows if my pio435 will work in spain ok, moving from uk in future hopefully, many thanks
  2. voxmagna
    voxmagna
    The analogue tuner will have to be set for PAL B/G for compatible sound, not sure if it's a menu option but check it out. They also use dual sound a lot on analogue.
    The Freeview tuner is DvB compliant so in theory should be compatible with their DTT broadcasts - but don't know how far advanced they are with their rollout.
    Doubt if the DTT EPG would work.
    If all else fails, you can connect any Spanish set top box/ decoder with a SCART outout and everything should work. as they are 625 and the audio is out on the SCART. Mains will be OK as long as it's 230, not much 110 around unless you are in the sticks.
    Hasta La vista Baby!
