plasma dust?
Discussion in 'Plasma TVs' started by jmack, Dec 30, 2003.
  1. jmack
    jmack
    hi guys
    i decided to clean my pc again on sunday and inside was thick with dog fur/cats fur/ human hair/ dust and loads of stuff.
    this got me wondering about my plasma that sits about 7 foot away from the pc , it has 2 long air vents at top and i think at bottom,
    its about 18 months old and i reckon it could be full of dust and fur, is there anyone /anyway of cleaning/ servicing it?
    i would not want to do it my self ......
    has anyone thought about this ? any ideads?
  2. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    Just stick the vacuum on the vents.
    That should remove any dust/fluff, etc. which has accumulated on or around the filters.
    I wouldn't even consider opening it up to clean the inside of the case...
  3. Andrew_B
    Andrew_B
    Dec 3, 2002
    198
    Bath
    I literally had a mouse inside my PC once! I couldn't work out where it was living, neither could the cats. Now and again it would appear alongside my monitor and then scurry away. I eventually narrowed it down to the PC when one cat spent nearly all day sitting by it. I had to take the front and sides off and shake it out into the garden. The little terror was getting in through one of those PCI slot covers which I had left off when taking out a redundant card.
    True story, honest!
    (your avatar reminded me)
  4. jmack
    jmack
    any ideas from joe f or liam would be great. what do you do with yours?
    andrew > tony montana reminds you of mice;) ;) ;)
