Plasma displays tuners
Discussion in 'Plasma TVs' started by yan, May 6, 2003.
  1. yan
    yan
    I am wondering what people are using for tuners for their plasma displays. I assume most people are using Sky, but there is talk of the BBC moving all of its channels to another satelite due to the extortionate prices Sky charges to host the BBC's channels.
    I assume people will then either add a freeview box or use a VCR as a tuner. However is a VCR a reasonable solution, is there any comprosmise in picture quality and are there any dedicated tuner boxes available for plasma displays?
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,303
    Newcastle
    +213
    The problem with a VCR would be that the output would be composite only (or S-video, if it was a S-VHS VCR). A freeview box would look like a better alternative.
    Arcam did do a NICAM tuner a few years ago. It is meant to be very good, if you can get hold of one second hand. I have heard of a few people holding onto them to use with projectors.
    Cheers,
    Liam
  3. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    From what I've heard about the BBC moving satellite, it won't really affect us viewers. Essentially, it's a move away from Murdoch's Sky tie in, which has more to do with the encryption of the channels. Over five years, it will save the BBC £85 million pounds.
    By moving to a different satellite, one which only transmits over the UK, there's no longer any need to encrypt what are "free" channels. Encryption is only there to stop viewers in other parts of Europe where the BBC don't have permission to broadcast program material from the copyright owners.
    You will not have to change satellite dishes or providers.
    More from the BBC website:
    http://news.bbc.co.uk/1/hi/entertainment/tv_and_radio/2929335.stm
    All the best,
    Dr John Sim.
  4. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    And getting back to the point of this thread...
    Digital TV is becoming the favoured method, tuners either via a VCR or external box, are used by some but once you start using the digital services you really don't miss analogue services.
    If you really need a tuner, use a VCR. But please consier Freeview, Sky or cable as alternatives - more channels too!
    All the best,
    John.
  5. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    Sky are moving their channels to Astra 2D from 30th May but that does not mean they cannot be received through a "sky" system as the satelite is co-located with the current one, indeed if they do go free to air as promised then any digital satellite receiver will be usable.
    There are a few stand alone receivers on the market Nexnix do something called Joyvision for £125 or Futurehome have a "AMC ProV TV tuner and Progressive Scan video converter" for £149. A video recorder seems cheaper option.
  6. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    I have same issue but do not have the luxury of Freeview as we don't get the signal and are unlikely to in the near future.
    Solution I am looking at is the ZINWELL ProV+ Prog Scan and TV tuner.
    Apparently this will not only give me the TV stations but also does a lot for signal processing.
    Good luck
  7. yan
    yan
    I also had a look at the ZINWELL ProV it looks very promising. I neglected to say in my original post that I am living abroad and so I dont have the luxury of Freeview or Sky(unless I install it illegally). It would be a shame to compromise the quality of my TV viewing by using a VCR, so The ZINWELL may be the way to go. Does anyone have this tuner?. Ive also thought about the scalers from JS Technology, however I assume if I plug a composite scart into the RGB to component scaler it wont actually output component as the input is composite and not RGB, can anyone confirm this?
    Thanks to everyone for their replies
  8. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Hi Yan
    Quick update. I spoke to someone whose opinions I trust on AV and they have stated the Prov range can be disappointing.
    I am going to email them and get the name of an alternative.
    Will update this forum when I get it.
    T
  9. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    It's worth checking out the ProV+ which has had a few improvements over the ProV based on customer input. The tuner's been upgraded to a decent Nicam stereo, fastext job and the processing has been looked at, upgrading the output to 60Hz or 75Hz plus a few other tweaks (now uses Philips SAA7118 chip).
    We'll have one or two on display at the showcase.....
  10. yan
    yan
    With regard to the ProV being disappointing, is it worse than having VCR as a tuner? Even with S-VHS the best connection is s-video, does it improve on that?
  11. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Yan
    I don't want to drop anyone in it or contravene rules so I will just say that there have been a lot of returns of the ProV due to awful quality pictures.
    The alternative I now have details on and have just ordered this morning to try out prior to my plasma arriving. If you go to AVer TV Box you will see the product for yourself.
    I will update this thread when I have the box tho obviously won't be able to feedback on plasma performance for a week or so.
  12. yan
    yan
    Great will look forward to heraing the results. The VGA connection should hopefully provide a better picture than an S-VHS VCR.
  13. yan
    yan
    Tommy, what will you be trying the box out on until your plasma arrives, LCD screen?
  14. markbuffyfan
    markbuffyfan
    if you are not hung up on teletext get a dvd recorder my panny e30 or the new e 50 can be picked up new for £355 multi region and its not a bad dvd player either
  15. yan
    yan
    Not a bad idea Mark, likewise what about HD recorders, they also have tuners dont they? Would rather get one of those than a VCR. Is anyone using an HD recorder/Tivo as a tuner for their plasma? Is this possible?
  16. yan
    yan
    Tommy have you also considered getting SKY without the subscription. Apparently it costs £130 for the dish and the digi-box and £100 for installation and provides 70 free to air channels. An alternative to A VER TV box
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Or buy a S/H Sky box and dish and do it yourself for £100 or less box £40+dish£25+ 100m ct100 £30
  18. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Well it arrived and I have tested albeit it on my 17" screen for the PC.
    It was pretty good as far as I can see. Really easy to setup and whilst it took 20 mins to get used to setting correct user channel numbers I cracked it.
    Only issue I have at moment is that teletext is not working so will speak to guys on Monday to see what I have missed or if they shipped me non-teletext version.
    Re Sky box I have one but since we have it and terrestrial piped through house I want Sky to be avail on other TVs in house whilst I watch analogue.
    Yes I know I could get Sky+ but I so detest giving them any more of my money and I think the extra monthly sub for another box (I know special offers etc come and go) is a complete rip off.
    I will further update when I get plasma.
    Tony
  19. yan
    yan
    Thanks Tony, glad to hear its wasy to set up, do you mind telling me how much it cost and where you ordered from. Ive looked at the site and the "where to buy" but its full of dead links. Thanks
  20. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Yan
    I actually called them directly and they shipped out immediately.
    I told them about web site as well
  21. dochall
    dochall
    Could anybody give me a supplier for the ProV+.
    Google is proving no help whatsoever.
    TIA
  22. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
  23. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    Yan
    I promised you update when screen arrived so here goes.
    The guys at Aver found box was faulty with Teletext so shipped new one out return.
    Plugged in tonight and TV really cool. Teletext is crap though so don't rely on this working too well if you want it.
    One real bonus tho is that my Sky box is a dual coax out which I split between old TV and the house feed.
    So I plugged the coax out from Sky into Aver and tuned Sky in and voila pictures from it seem really good from normal channels and Sky !!
    So much so that when cables arrive I think it will be a close call between output from Aver and JS converter for Sky.
    Anyway hope this helps.
    If you get ProV+ please put your thoughts on the forum.
    Tony
  24. mrv
    mrv
    Feb 3, 2003
    150
    Portsmouth, England
    Can you tell me what the problem was with teletext. Unfortunately 'er indoors must have teletext on the soon to arrive (hopefully) Panasonic plasma and I have discounted getting the panny tuner.
    Maybe I'll have to see how good the ProV+ is with text.
    (PS. Before anybody suggest it - freeview not an option, can't get a signal in my area. Digital is via NTL - decent, wife approved, text non-existent).
  25. tonymccandless
    tonymccandless
    Apr 23, 2003
    148
    Scotland
    +3
    I found the teletext to be far too blocky and not responsive to page changes as fast as a CRT built in which is pretty poor.
    I will see how things go over the next week or so and might order the Prov+ to try it out or consider a card for the MXE which has tuner built in.
  26. mrv
    mrv
    Feb 3, 2003
    150
    Portsmouth, England
    I notice that the ProV+ has RGB loop through from VGA input to VGA output when the unit is on standby. Now, being a bit thick, does this mean that I could feed :
    NTL RGB -> JS RGB-VGA -> ProV+ VGA In
    and then
    ProV+ VGA Out - > Plasma VGA In
    in the quest to get Teletext which 'er indoors wants (just like proper telly). Or is the output from the JS RGB-VGA box not compatible with the ProV+ in some sort of way??
    Mike
  27. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    I believe that the Pro-V will pass any input on the VGA through, so it should be compatible with the RGB to Plasma VGA unit.
    All the best,
    Dr John Sim.
  28. mrv
    mrv
    Feb 3, 2003
    150
    Portsmouth, England
    Symanski,
    Thanks. Might just have to get one and try it. Would you expect there to be any significant signal degradation by routing the VGA in this way or is it likely to be so marginal that it's not worth worrying about?
    Mike
  29. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    If the Pro-V has been designed correctly, there shouldn't be any deterioration of the picture, but I've never looked at one so can't say. You can certainly experiment by going via the Pro-V and direct.
    All the best,
    Dr John Sim.
  30. MobileInEurope
    MobileInEurope
    tonymccandless,
    I also tried an Aver TV Box but I am returning it because of serious picture delay, causing very obvious sound sync problems.
    Are you not experiencing this ?
    carsten
