Plasma displays and 16:9
Discussion in 'Plasma TVs Forum' started by Analogue, Apr 22, 2007.
  1. Analogue
    Analogue
    Please excuse me if I seem a bit thick but looking through the FAQ's and a Forum search does not seem to throw up an answer.
    I have been an avid reader and commenter on the LCD Forum for several months and having not found my ideal LCD at the right price I started to consider a Plasma (37" Panasonic 70 series).
    However I find that the resolution is quoted as 1024x720. This does not correspond to 16:9 whereas LCD's are 16:9 (1366x768).
    Can someone explain how this works?
  2. aktiv
    aktiv
    Apr 9, 2007
    53
    +14
    The pixels are not square, they are rectangluar.
  3. Analogue
    Analogue
    Thanks that explains it - but surely this means the horizontal resolution is compromised?
  4. johndon
    johndon
    Feb 3, 2002
    1,989
    63
    +122
    And the screen incorporates a scaler to ensure the image is displayed in the correct aspect ratio.
    John
  5. Analogue
    Analogue
    Thanks also but ditto to my previous post?/ c/w an LCD that is?
  6. aktiv
    aktiv
    Apr 9, 2007
    53
    +14
    On paper, compared to a 1366-wide LCD you would have to say yes. But in the real world, side-by-side, you'd be hard pressed to spot any difference (apart from the fact the plasma would probably have the better PQ!). Our eyes are not as sensitive to horizontal resolution it seems.
  7. johndon
    johndon
    Feb 3, 2002
    1,989
    63
    +122
    An LCD would have a scaler as well as, although the resolution may be 16:9 it doesn't match the resolution of the source so it has to be scaled anyway but, as the previous poster mentioned, you'd be hard pushed to tell the difference.
    John
  8. Analogue
    Analogue
    Thanks to you and Aktiv - I fully appreciate scaling applied to LCD's.
    However this may explain why I have felt that Plasmas never seem to look quite as "sharp" as LCD's on HD although they certainly look better on SD - which is my main issue with LCD's
  9. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Up close, as you tend to be in a shop, LCDs do look sharper with HD material but from a few feet away that difference soon fades away.
    Pioneers look sharper than Panasonics too but I still prefer the image on a panny.
