plasma dilema
Discussion in 'Plasma TVs' started by philinman, Nov 2, 2003.
  1. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    Right i am going for a plasma after xmas it will be a panny 6 50inch or the pioneer 50inch 504 the problem is does any have the distance it will stick out from the wall when mounted using the wall bracket ,
    As i am going to have a problem as my M5C speaker is very deep 220mm what have people done for a center speaker when the plasma is mounted to the wall i will have a fire place under mine.
    Any ideas will be good as it all needs to be just right :clap:
  2. jont
    jont
    Apr 8, 2002
    3,938
    near Aylesbury
    +416
    Most plasmas stick out around 60-90 mm from the wall to the front of the screen if you have a 'flat' wall mount ... if you have a tilting one the top of the screen will come out about 150mm ...
    My panny is 72mm from the wall and checked every month or so just so I know it's not going to fall off ;-)
    HTH
    Jon
  3. cheesyhammyeggy
    cheesyhammyeggy
    Have you looked at the Mission m7c1, its quite a flush design, I am going to fit my plasma over a fireplace and as I can't afford to change my Mission 780s it is the only feasible match.
  4. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    MMM that might not be to bad then mounted above on slight down facing angle or below on a bracket ??
    will have the get the plasma and see i will be going for tilt bracket i think :clap: :clap: :clap:
