Plasma Corner Wall Mount
Discussion in 'Home Cinema Buying & Building' started by bobbybox, Oct 30, 2004.
  1. bobbybox
    bobbybox
    Does anyone know if anyone makes a wall mount for a 42" plasma screen for a corner (ie across two intersecting walls)?
    thanks
    Bob
  2. bobbypunk
    bobbypunk
    www.vogels.com
    You're looking for the EFW2009 (About £300)
    or the EFW2010 (About £450)
    These pivot at the wall and at the screen so you can go across corner, they will also tilt up to 15 degrees!
  3. bobbybox
    bobbybox
    Thanks Bobbypunk. Guess I'd better start saving :eek:
