Plasma convergence
Discussion in 'Plasma TVs' started by Timmy B, Sep 23, 2003.
  1. Timmy B
    Timmy B
    Can plasmas suffer convergence problems?
    The 6 series panny which I had working for a few days (it's being sent back now for other reasons) had a red outline on some stuff, most obvious on the left hand side of the sky "search and scan" banner. It could be seen from 10 feet away.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    COuld be the chroma bug, older sky boxes suffer more from this.
  3. Timmy B
    Timmy B
    No I dont think it was the chroma bug - you can only see it outlined on some white sources, like the left edge of the search and scan banner. If you go up close you can see red pixels outlining the white edge. Also, at the "no signal" screen you can see a red outine.
