plasma connection to pc via DVI
Discussion in 'Plasma TVs Forum' started by skinleverton, Jan 6, 2005.
  1. skinleverton
    skinleverton
    Need some good advice on a snag i have.
    I have a hitachi pd 42 5300 plasma with DVI input and recently purchaced a 10m DVI to link to my pc the graphics card is an xfx geforce 6800 with duel DVI. after connecting the plasma screen shows the picture but it is very patchy in lots of different colours. i have linked the pc with the standard cable and all is well. is the cable to long or just faulty?
    :lease:
  2. Neil69
    Neil69
    Jun 8, 2001
    314
    9
    Leigh
    +17
    Hi, I have a 42PD5200 connected to my PC via DVi. I have no problems with it whatsoever.
    Have you tried to change pic res? You set that up via the PC. Have you set the DVi setting to PC?
    Ta, Neil
  3. philipb
    philipb
    Mar 6, 2002
    2,065
    63
    Swindon
    +155
    10m is pushing it for DVI - if the cable is not high quality you probably would get picture artefacts.
    I'd recommend a shorter and/or better cable.
