Plasma connection problems!
Discussion in 'Plasma TVs Forum' started by simon33, Mar 17, 2005.
  1. simon33
    simon33
    I have just bought a Sony surround system and I'm having some troubles in connecting this all up.
    I've managed to get the DVD and TV working, but I'm completely puzzled as to how to connect the Video to the surround system.
    The only output on my video player is a scart lead, and of course the sound system does not have a scart port on it.
    Could anybody give me any clues from getting the audio from the video player? If it helps, I'm using a LGRZ42PX11! :)
    Many thanks in advance,
    Simon.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You'll need one of those scart adapters with 3 phonos on it. Beware they are directional unless equipped with a switch. An alternative if you are connecting scart to scart to the screen, does the screen have audio out? That would then work for analogue TV as well as video
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
  4. simon33
    simon33
    Thank you very much MAW and mep, I'll pop out tomorrow and get myself one of those cables.
    Thanks again,
    -Simon-
