Plasma Cleaning
Discussion in 'Plasma TVs Forum' started by brillo, Jun 10, 2004.
  1. brillo
    brillo
    Ive just bought a Samsung 42" Plasma TV and im very satisfied, however i want to make sure i make every effort to treat it well so im calling on everyones expertise on how to clean it, in particular the screen. I dont want to scratch or smear it in anyway.
    Thanks. :smashin:
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,461
    Newcastle
    +290
    A quick use of the Search facility (on the blue bar, 3rd from the right) came up with this.
    Cheers,
    Liam
  3. BuzzLightyear
    BuzzLightyear
    Jun 3, 2004
    167
    16
    I've just looked at the link mentioned in the sarcastic post above. Its all very well if the original poster has crayon on his screen, but I think he is probably wanting some advice on general day to day cleaning - finger prints and the like - and alcohol based cleaners seem a little over the top - and quite often leave a residue on surfaces.
    Buzz
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Personally I use cloths designed for cleaning CD's. The front screen on a plasma is plastic, you have to be pretty gentle with it.
  5. consciouspnm
    consciouspnm
    Jul 24, 2003
    Huddersfield
    I use the special cleaning cloth I got with my 433MXE
  6. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Unless you've got sticky fingermarks or are a heavy smoker I'd suggest a feather duster will suffice.
  7. lmccauley
    lmccauley
    Oct 24, 2000
    3,461
    Newcastle
    +290
    I was actually trying to be helpful in pointing out where the search facility on the site is, as it could easily be missed by a relatively new poster. I did a search for "plasma cleaning" and picked one thread at random from the list given. Is that so sarcastic?
    Cheers,
    Liam
  8. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    I'll back up lmccauley on this. There have indeed been several threads on this, I have contributed to at least one of them, in which I gave advice on basic cleaning (eg fingerprints).
  9. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Alcohol based cleaners are actually very mild, much more problem is the detergent. If you want something that will clean relatively gently with no smear, look for a very mildly ammoniated ethanol based solution. You likely have to accept some detergency but this does the cleaning of oily things (eg. fingerprints) no harm at all. The ammonia helps avoid smearing.
    ad
  10. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Personally I read it as helpful rather than sarcastic but Liam please bear in mind the First Rule of Management: "Anything you do, say or write will inevitably be interpreted in the most sinister possible light"!
  11. Sicilian
    Sicilian
    Jun 8, 2004
    1,300
    48
    North London
    +27
  12. JH4
    JH4
    May 6, 2003
    2,420
    83
    +264
    For glass Plasma screens use Methylated spirit applied with some soft loo roll to take off finger smears etc.
    No residue, no problems.
    For LCD plastic screens use plain water, applied the same way.
  13. scoooby
    scoooby
    Mar 22, 2004
    104
    A bit of saliva and an old sock normaly does the trick.
    SShhh.. keep the secret safe..
  14. lmccauley
    lmccauley
    Oct 24, 2000
    3,461
    Newcastle
    +290
    Of course, why didn't I think of the mothers' method of cleaning their children's faces? Spit and a tissue.
    :thumbsup:
    Cheers,
    Liam
  15. BuzzLightyear
    BuzzLightyear
    Jun 3, 2004
    167
    16
    No insult was intended and I wasn't trying to be sinister - its just the way I read it.
    Its Friday lets chill
    Buzz
  16. Wazy
    Wazy
    Jetwashers are on offer at B&Q :laugh: :laugh: :laugh:
    Should get them damn finger prints off :D :smashin: :beer:
  17. lmccauley
    lmccauley
    Oct 24, 2000
    3,461
    Newcastle
    +290
    None taken. I'm on holiday today, so am well chilled :D
    Cheers,
    Liam
  18. saturday
    saturday
    Feb 9, 2003
    Sussex
    I found this exchange in a newsgroup (read to end) :)
    Subject: Monitor Screen Cleaners - question.
    Date: Thu, 15 Jan 1998 09:17:29 -0000
    Hi folks, as you will all know ' proper ' screen cleaners are
    expensive and I have often been disappointed with the results.
    Does anyone know if its safe to use just an ' ordinary ' household
    glass / window cleaner such as ' Windolene ' or not ?.
    Will it damage perhaps the ' special ' monitor coatings ?.
    Must confess that I have just tried it out, and it does a first rate
    job - my screen has never looked better but am a bit worried
    about the long term effects.
    Any advice greatly appreciated. Thanks folks.
    Regards, Mike.
    Subject: Re: Monitor Screen Cleaners - question.
    Date: 15 Jan 1998 09:39:49 GMT
    From: "Douglas Gregory" <**********@btinternet.com>
    Would be just a little wary about stuff like Windolene as they have
    solvents and mild abrasives in them could damage the anti-glare coating on
    the screen. Probably be OK provided you do not use it too often.
    What I use is a little bit of neat washing up liquid on a damp soft kitchen
    roll. Then use another piece of damp kitchen roll to clear it all off
    (works well on cases and keyboards too just don't have the kitchen roll too
    wet).
    Douglas
    Date:Thu, 15 Jan 1998 11:05:57 -0000
    Just use any glass cleaner spray. Or wipe over with a damp cloth
    dunked into the dish washing bowl. Dry off with Kleenex.
    Date:Fri, 16 Jan 1998 08:33:57 GMT
    I've always just used flem and bog roll, then wipe off with dry.
    It works well but make sure that you do it before a liquid lunch <g>
    Date: Fri, 16 Jan 1998 11:19:39 -0000
    From"Peter Fletcher" <*********@btinternet.com>
    Oh I see -- you mean "phlegm" -- eeuuk messy and unhygienic - still I
    suppose the x-rays from the tube might kill the germs.
    Date: Sat, 17 Jan 1998 18:07:28 GMT
    No, I meant Flem... my next door neighbours' bitch poodle.
    Since I started using her, all sorts of bumps have started appearing
    that make her great for cleaning the muck out of the corners. Could
    that be because of the x-rays ?
    Before you ask, Dry is my hampster.
