cebs_uk
This may have been covered before but I was wondering if what the definitive spec for a new full/true HD panel is. Every issue of HCC seem to point out new faults with kit specs that are then not mentioned in reviews of similar kit. For example in this months issues a lot of plasmas are noted for not being compatible with 1080p 50/60 Hz which I haven't seen before in previous issues.
From reading the review of the hd-xe1 it seem it can or will soon be able to output the following :
1. 1080 24p
2. 1080 30/60Hz
3. 1080 25/50Hz
So is that a checklist of the 1080p modes that I should look for in my new screen or are there more?
I would like HCC to update their spec boxes and show the same info for all types of plasma/lcd/proj as it is pretty hard to keep track of spec at a glance at the moment .
Thanks in advance for any help.
Cebs
1. 1080 24p
2. 1080 30/60Hz
3. 1080 25/50Hz
Cebs
