Plasma Cabling Help
Discussion in 'Cables & Switches' started by toastfrenzy, Sep 17, 2004.
  1. toastfrenzy
    toastfrenzy
    Sep 17, 2004
    26
    4
    I have an NEC 42MP3 plasma screen and now have been given a Sony DAV-SR2 which only has a SCART(RGB) connection for the screen output. My plasma does not have a scart input. Can I get a scart to component cable or will i need a converter (or similar). The book that comes with the DAV SR2 says "note, this unit does not output s-video & component signals."
    Below are the 3 rgb inputs for my plasma, Can I get aSCART (RGB) to 5 BNC (RGB/HV) cable or SCART to DVI
    RGB 1 (analog)- 15-pin mini D-sub
    RGB 2 (analog)- 5 BNC (RGB/HV)
    RGB 3 (digital)- 29-pin DVI (digital only)
  2. toastfrenzy
    toastfrenzy
    Sep 17, 2004
    26
    4
    After e-mailing/phoning around finally got on to this....
    Syncblaster cable
    So £80 later and nextday delivery (bought from www.AV-Sales.com )
    I now have everything as it should be. :clap:
