Plasma Cable Emerging from Wall
Discussion in 'Home Cinema Building DIY' started by Tantalus, Nov 11, 2004.
  1. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    Rather odd question: I am about to purchase plasma with sep. Media box + 10 extension cable. Issue here is that I need to run the a 10m cable from media box to Plasma connection cable under the flooring. What I am struggling to solve is how I can neatly route this rather hefty cable via sockets. Because this is unbroken I was hoping I could find (without success) some stainless steel sockets - with a black 'letterbox brushes" centre which to route the cable through. Not sure if that is very clear! Help appreciated! Does anyone make these?
    Graphic design is not my forte!
    [​IMG]
  2. Oi Oi Savaloy
    Oi Oi Savaloy
    Jul 26, 2004
    140
    Chertsey, Surrey
    +12
  3. Gojira
    Gojira
    Jul 13, 2002
    19
    Black brushes?
    What, like a letter box?
  4. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    Yes like a letter box! And don't suggest I use one! Perhaps rubber might do also. QED only seem to do satin face plates with a big hole. Seems like there is a gap in the market for continues cable face plates!
  5. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Tantalus,
    If the QED Satin faceplate has a big enough hole to fit the connectors through, then how about buying a cheap plastic letter box flap with brushes, removing the brush strips from the letterbox, cutting them down to size and glueing the bits of brush strip with hot melt glue gun or araldite etc to the back of the faceplate ?
    Also if the faceplate will be hidden behind the plamsa does it need to be a satin metal one, doubt it will be seen.
    Good luck !
    Mark.
  6. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,350
    Livingston, Scotland
    +227
    Tantalus
    Take a trip to your local Homebase or B&Q for a look on what's on offer:thumbsup:
  7. cwoj
    cwoj
    rs components do a 30cm plate / brush strip. It has 2 x screw holes so you can drill a biggish hole pop your cable through and then screw the plate on, giving it a nice finnish. The plates come in white and brown and cost about a fiver.
  8. brendank
    brendank
    Dec 13, 2003
    684
    drogheda, co louth,ireland
    +6
    thinking outside the box today
    was in local diy shop today and seen a wall plate fixing for connecting to flatventilation system which looked like what you need minus the rubber seal/flap. cost 1.63 euros
    might be worth checking out in bq next time your there
