Plasma burn-in, or faulty panel?
Discussion in 'Plasma TVs Forum' started by kevo82, Aug 9, 2013.
  1. kevo82
    kevo82
    May 17, 2010
    117
    Dancing pixels on faulty panel, or plasma burn in?
    After 2.5 years of normal use, my Panasonic 50VT20 plasma has a huge thick vertical stripe of inversed pixels in the upper left corner, down to half of the panel height.
    What do you guys think? It's a faulty panel? It doesn't look like a plasma burn-in, because doesn't retains images, just a purple/blue stripe of dancing pixels.
    I still have warranty, because the TV had 5 years of warranty.
    They could fix it, or exchange the TV, with which other actual Panasonic TV? If I payed 3000$ for the TV, how should I be covered by the warranty?
    I posted photos:
    [​IMG]
    [​IMG]
  2. SaNDuTjE
    SaNDuTjE
    Jul 30, 2013
    72
    +7
    100% faulty panel.
    Contact your dealer, service center or Panasonic and make room for a VT60 :)
  3. kevo82
    kevo82
    May 17, 2010
    117
    It sounds to good to be true :)
    I have a little worry though. The store where I bought the TV from, I think that they don't get their products directly from Panasonic, and they might got my VT20 from the grey market (meaning a retailer from other european country).
    I know that they brought it from Germany, (maybe Panasonic Germany), and I had to wait 2 weeks until they delivered it. I really hope the 5 years warranty, was directly from their provider, because normally all TVs have a 2 year warranty...mine has 5 years warranty, and I bought it, almost 3 years ago.
    I payed 2300€ (2000£) for it, and on the receipt, it's written the date of purchase, and 60 months warranty.
    So, you also think that, from the photos, that is a faulty panel, also known for ST and GT series, covered by warranty...?
    Are you sure that they will just replace my TV with a 50VT60, without paying any difference?
    God I hope you are right :D
  4. SaNDuTjE
    SaNDuTjE
    Jul 30, 2013
    72
    +7
    Since you have warranty on your screen and there are, i assume, no spare parts available for the VT20 anymore it's cheaper for them to replace it.
    But to be really sure contact your dealer first.
  5. kevo82
    kevo82
    May 17, 2010
    117
    I did. They said that I have to bring them the TV, and they will see what they can do.
    I hope they will at least fix it, or even better, replace it with a VT60 :laugh:
    Until now, I've been told that "they can offer to repair, replace or refund minus any 'fair use'."
    I hope this will be no issue, and I'll be able to watch US OPEN on a new VT60 this year :laugh:
  6. SaNDuTjE
    SaNDuTjE
    Jul 30, 2013
    72
    +7
    If they've already suggested that and assuming that repairing is no option things will probably work out just fine :)
  7. kevo82
    kevo82
    May 17, 2010
    117
    Thanks. I hope you'll be right. I'll post the results in a few weeks :smashin:
  8. kevo82
    kevo82
    May 17, 2010
    117
    I just took the TV back, and they said they will repare it, and in the worst case they will change the panel.
    So unfortunately I won't enjoy a VT60. I hope the TV will explode, burn or something, in the next few days :))
