Quantcast
Plasma bracket for old then new panasonic
mikebh41
Currently own a Panasonic TH-37PV600 but will be getting a VT50 but want to mount the PV600 on the wall and get the cables chased in ready till i do change so the question is can i get a bracket that will work with both any advice or links would be great .
Mike
GoNz0
whats the mounting on the current telly, the 50" is 400mm wide and 300mm down for the vesa on the ST30, if the one you have is the same then I can't see a problem.
just make sure you can slide the cables into the wall as some complete plonka who booked a sky+ box swap had done the cables dead fit, the new box i arrived with had a different layout and that wasn't my problem!
