Plasma aspect ratios..?
Discussion in 'Plasma TVs' started by SimonO, Aug 1, 2003.
  1. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Okay, I've got my head round the vertical (or is it horizontal..?)resolution issue and have got my 42/43"shortlist down to the Panasonic HD6, Pioneer 433MXE and 434HDE...
    However I'm now really struggling with the aspect ratios... 1024 x 768 = 4:3 but the screen is physically 16:9 so it has rectangular shaped pixels..? Surely this cannot be ideal...
    However the standard 'low resolution' 852 x 480 panels are 16:9 and therefore I assume square pixels..? Better..?
    How do the native 1024 x 768 panels display a true 16:9 input..?
    Or am I totally missing the point..?
    And I thought choosing a plasma would be easy..!
  2. tbrar
    tbrar
    May 31, 2003
    609
    16
    SimonO,
    Below is an extract discussing the shape of pixels taken from AVSFORUM:-
    Yet another aspect to consider in the plasma purchase ! :eek:
    Hopefully that helps a bit
    Tony
  3. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    Thanks Tony... So I cross it off the list of things to worry about..!?
    PS... Its looking like the 434HDE at the moment (mainly cos it looks so good)...
    Thanks for the info yet again...
  4. tbrar
    tbrar
    May 31, 2003
    609
    16
    Simon,
    Yes, thats one that I wouldnt & didn't worry about.
    If I were you, and youve got the cash, look to the future ! - the latest generation HD displays of the Pioneers and Panasonics are certainly the two that I would short list.
    I like the Aesthetics of the new Pioneer 434HDE as well, it looks pretty smart.
    Happy viewing :smashin:
    Tony
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Lat addition here, it does matter if you want to display PC sources, but even then mostly you can see a windvd or similar image OK, it's just web or text that looks silly if yoy have a rectangular pixel screen. The 503mxe you can't really tell, the stretching is pretty small, only 6% or so.
  6. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    SimonO
    It sounds to me like you may want to go for the HDE purely for the simplicity of setup and connectivity. On various occasions MXE owners have had to add format converters and switchers, which not only adds cost but can get complicated for someone breaking into this hobby.
    Rgds
    Snowman
