Plasma aspect ratio options
Discussion in 'Plasma TVs Forum' started by eddyad, Dec 27, 2004.
  1. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    I currently have a Sony widescreen TV and a Freeview set top box. The TV is set so that all digital WS programs automatically display in 16:9 format and all digital and analogue 4:3 programs in 14:9 format, regardless of source - TV tuner or AV inputs.
    The 14:9 option makes better use of the screen with minimum loss of image - just a small amount top and bottom, sometimes no loss at all as many 4:3 programs have narrow black bands top and bottom.
    Apart from Sony are there any other Plasma TVs which will do this? I've downloaded some manuals and it seems that the only options for 4:3 transmissions are: 4:3 with wide side bands, 'Zoom' with significant top and bottom loss to fit screen width or 'Smart' with progressive widening of the sides of the image (and presumably black bands top and bottom when the 4:3 image would have them).
    The 14:9 option should work for AV inputs as well as inbuilt tuner(s).
    Am I asking for the impossible or just a Sony?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    The Hitachi 42PD5300 has a 14:9 mode as well as a 14:9 zoom mode.
    John
  3. Lee James
    Lee James
    Dec 11, 2004
    315
    Mine's a Hitachi 42PD5200 and it has all the zoom modes you could want.
    I'm using the 'panoramic' mode for all 4:3 broadcasts. It chops a little off the top and bottom (so little you'd never see it), keeps the middle undistorted, and stretches the sides out to fill the screen. It works brilliantly, and as my plasma's brand new it's important to keep the screen filled as much as possible to prevent screen burn. If you are going to have bars either side, make sure they're grey and not black.
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Thanks. My Sony's 'Smart' is the same as Zoom then, but I think I prefer the 14:9 option. 4:3 by itself looks like an island even on a 32" TV.
    So my next question - is the Hitachi Plasma good quality/value. We also has a normal Hitachi 28"WS TV and that's OK.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The Hitachi has won lots of awards. The price is a little higher than some other makes.
