Plasma and Telewest
Discussion in 'Cable TV & Virgin Media TV' started by GASWATKINS, Mar 24, 2006.
  1. GASWATKINS
    GASWATKINS
    Mar 11, 2003
    245
    +10
    Love my new Panny 37 PE50
    but telewest box seems to act up on its own changing the display
    changing channel
    does plasma in some way set off remote control ?
    did i read about this on an old thread or am i dreaming
  2. Fontie
    Fontie
    Dec 7, 2004
    196
    Yeading
    +11
    My TW box developed a mind of its own after i got my plasma changing channels and bringing up this and that I put it down to stray signals from a neighbors remote. Seeing your post looks like its the plasma affecting the TW box. Ive got TV drive now and all is fine.
  3. nokiauk
    nokiauk
    Dec 28, 2004
    888
    Edinburgh
    +47
    it was on an old thread which i was also a contributor too.
    had a similar problem with random channel changes, menus etc.
    i think the answer given was due to infra-red radiation from the plasma, nothing i done stopped this happening. I now have the new TV drive box from telewest and problems have gone away.
  4. thegasman
    thegasman
    Hi, I was also involved in the old thread, I had the same problem, I had the old PACE box then. Telewest first changed my remote which made no difference, then they changed the box (twice) which didn't sort the problem either. Finally after me insisting they changed the box for the newer and smaller EXPLORER 4200 DVB
    Since then, which was about 3 months ago, i hav'nt had had any trouble at all.
    Apparently the PACE box was picking up IR signals given out by the PLasma
    Just pester them to change your box, it WILL sort it.
    Hope this helps.
  5. GASWATKINS
    GASWATKINS
    Mar 11, 2003
    245
    +10
    Thanks the thegasman
    will get on to them ASAP
