plasma and screen-burn
Discussion in 'Plasma TVs Forum' started by 7MAT, Sep 25, 2003.
  1. 7MAT
    7MAT
    Sep 8, 2003
    168
    SURREY
    +8
    The other morning my daughter wanted to watch Monster Inc for the 100th time. After the movie finished the menu screen for the DVD popped up and stayed there.
    After about 20mins I switched it off, to find that the image was still on the screen, but very faint. I believe this is called screen-burn.
    Switched the plasma over to SKY for a bit and then I switched back it had disappeared.
    My question is how carefull do I need to be?
    Should we all be worried about channel logos and red dots on SKY+?
    I have also heard that there is an engineer DVD, which flashes bright colours to repair screens with screen-burn? Are these available anywhere?
    7MAT
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Forget repair. What you saw was just after image. I've known it be bad enough to last 2 weeks!! It's gone now though, I got it in the exact same way you did. If you've really cooked it there's no going back..... Just ordinary caution is sufficient. Turn the conrast down a bit, never let the red dot hang around, don't watch the same channel with a logo for all day, and turn it off when the dvd is finished. Don't get paranoid, it's not that easy to ruin one.
  3. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    Check some of the other (numerous) threads on here about this, it really is nothing to worry about. I have a" budget" plasma and use it as a pc monitor (lots of static images) as well as a TV and for viewing dvd's, I have never had a problem in 7 months of use
