Plasma and PS1
Discussion in 'Plasma TVs Forum' started by novicegeek, Mar 24, 2005.
  1. novicegeek
    novicegeek
    Hi people.
    Wonder if you could help. I have a PS1 and a panny TH6. I have been trying to conect the two for a while now without success. I have bought myself a PS1/scart lead and have attached the scart to a JS converter. No signal.
    Is there anybother way to connect these 2 pieces of equipment??!!!
    My other setup is :
    Sky+ to JS Box
    DVD to panny via component.
    Both Sky+ and DVD player connected to Bose Lifestyle system for audio.
    Any help would be appreciated.
    Thanks! :lease:
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    can the ps1 do rgb?......and if so is the scart rgb? often the basic connectors that come with consoles are not
  3. novicegeek
    novicegeek
    Does this mean that they cannot be connected together??
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You can connect it with composite, I don't think it can do RGB.
  5. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    I do think that the sony can do RGB , you just need a good RGB SCART cable. The same one you have to use when your PS1 is chipped.
