Plasma and PC's
Discussion in 'Plasma TVs Forum' started by kevb, Jul 2, 2002.
  1. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    Anybody know of a Plasma Screen that can recieve IR signals to control a PC.(Mouse Movement)
    Or would It be easyest to buy a wireless mouse.
  2. Kirk
    Kirk
    Jul 2, 2002
    309
    Somewhere on t'internet
    I am not positive that I am with you there?!?
    The plasma screen is just a display. If you are using a mouse or pointer, then it's the PC or whatever that needs the IR device attached to it.
    Most Company Boardrooms will have a PC hidden away with an IR receiver attached, the peeps who are doing presentations etc will just point their wireless device in the general direction of the IR receiver, whic typically is just visable somewhere and Roberts your fathers brother!
    The plasma screen just connects to the VGA signal of the PC like any normal monitor or projector.
    I think that is the kind of situation you are asking about?
