If you considered the commercial panny panel then you could probably go up to the 42 as it has similar if not smaller dimensions to the 37 Vierra. Having said that you would need an AV Amp and Speakers and to be using Sky or an external tuner source.
Sorry, don't mean to cause any further indecision but if you are after maximum screen size then this is a very good option if you are ok using and AV Amp and speakers when watching TV.
