Plasma after-images
Discussion in 'Plasma TVs Forum' started by 911uk, Jun 18, 2002.
  1. 911uk
    911uk
    I've read a few peoples comments regarding how static images can ruin a plasma, but what's the official line on this?
    How long must an image be displayed before it causes a problem?
    For example, if I decide to use my plasma with the pc (which it was designed for) and spend a lot of time using Internet Explorer/Netscape etc, should I be concerned that the window frame and buttons will cause permanent damage if used for say, 4 hours a day?
    And why would watching sky cause a problem?
    Is the problem confined to Plasma, or is it the same with rear projection, front projection etc etc.
    Cheers all,
    Phil.
