Plasma Advice Please (and Potentially Dumb Question)
Discussion in 'Plasma TVs Forum' started by warrj, Oct 7, 2004.
  1. warrj
    warrj
    It's now just over five years since I bought a 'stopgap' RP Sony TV. I use the word stopgap because I intended to replace it with a plasma once prices had dropped sufficiently. So, five years on, are there any plasmas which are currently available or soon to be available which meet the following criteria:
    37" screen size
    HDMI input
    Hi-Def TV compatibility (I'm not sure what this means in technical terms)
    As a supplementary question I would like to ask: Can current plasmas really be unambiguously defined as being HD compatible? Does the current definition of HD-compatible merely mean that from the tech specs a given plasma should be HD-compatible or is it more black-and-white than that?
    Thanks in advance,
    Jules.
  2. warrj
    warrj
    Anyone?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    TH-37PW7BX Panny is best bet for a 37" With HDMI HI-def compatibilty if not Hi-DEf resolution..... need to go 42" for this.........
    Awaits flaming from Hitachi owners :D
